PV Worker Common File System Permissions
On one network, I have:
* Windchill running as a service owned by Local System.
* On the worker machine GSWorker is running as an actual user. (Needed because we are using SSL)
* I have two worker machines, one for MS Office type files and another for ProE files.
* One is configured with an FTP server the other just uses a common file system path.
* This setup works.
On our other network, more secure, I have: essentially the same thing except currently I only have one worker machine.
* Windchill service owned by Local System,
* GSWorker service owned by a real user.
* Using a common file system path
* This setup fails, log file says:
Problem creating directory \\<server-name>\cad_viewables\w1i1j2. It already exists as a file
Problem creating directory \\<server-name>\cad_viewables\w1i1j2. Do not have write access
From the windchill server I can write, & delete files in \\<server-name>\cad_viewables\<file: \\%3cserver-name%3e\cad_viewables\="> No problems
The hot-line is trying to tell me it's because I have Windchill running as Local System. I'm not convinced. Does anyone know for sure what user is writing the files in that location?
Also can I get around this permissions issue by using an FTP server?
David Haigh
Phone: 925-424-3931
Fax: 925-423-7496
Lawrence Livermore National Lab
7000 East Ave, L-362
Livermore, CA 94550
* This setup works.
David Haigh
Phone: 925-424-3931
Fax: 925-423-7496
Livermore, CA 94550
