When performing a Mass Change - Replace Existing Part, all Custom Part Usage IBA values are automatically filled in. When choosing Insert Existing Part, none of the Custom Part Usage IBA values are filled in.
Is there an easy way, configuration without customization, to add Custom Part Usage IBAs to this Mass Change Window?
If the system would use the Default value for these Part Usage IBAs, defined in the Type and Attribute Manager, it would be fine too.
Windchill 10.1 M030
