Poor performance observed in Add to Workspace with MS SQL 2005 Database+WC9.1M060
  • July 23, 2013
  • 1084 views
We are on Windchill 9.1M060 and migrated from Oracle to MS SQL 2005 recently.
Now users are observing Poor performance in below actions if performed in pro/e embedded browser.
Add to Workspace,
Workspace Rendering,
Checkout,
undo check out
Issue is happening frequently now.
If around 150 components are already there in workspace and user tries to add 2 components to same workspace it takes around 7 mins.
Any suggetions over performance improvements?
23-Emerald I
July 23, 2013
Can you verify if any of the following are applicable:
https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS77509
https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS56366
http://www.ptc.com/appserver/cs/view/solution.jsp?n=CS62243
If those don't yield any helpful results it may be a good idea to generate a Windchill profile or use the MS SQL Server tools to verify whether there is any long-running SQL causing the problem. It may be necessary to create/change some indexes to help improve performance.
I assume that this occurs in both standalone and embedded browsers?
alonkar-21-VisitorAuthor
Hi Lori,
The issues is observed in case of embedded browser only not in standalone browser.
Best Regards,
~Amit Lonkar
23-Emerald I
July 29, 2013
If you haven't done so already, you may want to open a Tech Support case for further investigation. It may be necessary to enable client-side debug logging as per CS48724 to get a better idea of what is going on the client to make the actions so much slower.
I also assume that this occurs with a new workspace cache and with the browser/java caches cleared, correct?
