Pro/INTRALINK TOOLKIT 3.4 Process on Server 2008 R2
  • July 3, 2014
  • 0 replies
  • 506 views
Hi ,
I am running a Pro/INTRALINK TOOLKIT 3.4 M062 app on Win Server 2008 R2. All seems to work well. However, over time the app crashes after about 2 days of uptime. The only indication I get is an Application Fault, EventID 1000 in the Windows Application Event log. All that is displayed is the path to the app and the parth to the oracommon10.dll in the Toolkit Environmet load point
My initial thought was that perhaps the app was leaking memory and reaching the 32 bit address limit, but logging the app's memory use dispelled that notion. The fail time is almost exacty the same each time, so that leads me to believe that some limit is being reached.
Has anyone elese seen similar behavior out of Pro/INTRALINK Toolkit?
Ben
