I want to be able to have a Library Read only member kick off the request to promote process. Currently we have a library manger give the user the original file. Once the edit is done the user gives it back to the library manager to upload to the system. Then we want the user to be able to do the request to promote. I have tried setting up the promotion notice and that did not work. We are on WC 10.2 M020.
These Users need:
- Read for the data being promoted (CAD Doc's, WTDocs, WTParts)
- Create for PromotionNotice object type at Open state (assuming use of the OTB Promotion Request lifecycle); read for All states
note: Look also at your current setting for the preference: "Access Check for Promote"
