Rename from Workspace is greyed out
  • May 24, 2022
  • 2 replies
  • 4418 views
One of the constructors has a problem with rename part. He has the same privileges and is in the same groups/roles but rename option is greyed out. Where did we suppose to look to fix it? It is urgent.
Best answer by MattPat
We found the solution and it is very odd too.
Changing the windows browser type to ie_browser in creo helps. I don't know why it was not working on chromium...
Is it checked in?  Then you cannot rename through the workspace.  You have to rename from a search.
@STEVEG,
It wouldn't have the new icon (asterisk) if it was checked in.
MattPat14-AlexandriteAuthor
No, they created a part in the workspace and can't rename it or change the number. They could do that in the workspace but for some reason, they can't now. Any thoughts?
This is very odd.
Question:
You said "One of the constructors has a problem with rename part."  Did you really mean "constructors" or did you mean "contributor" like in the image you show.
If you did mean contributor then I assume both users are in that role?
MattPat14-AlexandriteAuthorAnswer
Wow!  I'm glad you found the problem.
