Reporting Endpoint giving 500 error when calling any Report.
CL_13728726
3-Newcomer
I am using Windchill PDMLink Release N/A and Datecode with CPS N/A
When calling any reporting endpoint using WRS, I get 500 null error message.
Example call to a basic report is
curl -X 'GET' \
'https://{serverName}/Windchill/servlet/odata/v3/Reporting/Workspcecontextusers?%24count=false' \
-H 'accept: application/json'
Here are the errors that I faced
The error message I get from the request is
{"error":{"code":null,"message":"An unexpected exception occurred during error processing"}}
Fadel
23-Emerald I
(To:CL_13728726)
Can you share the error from the MS Log
Fede
Hi @CL_13728726
As recommended by @Fadel, could you please add more details and context to your topic. You could also add, screenshot(s) to the topic.
If you are in a position to respond to this question, that would be great. It could help you to receive an answer to your question.
Vivek N
Community Moderation Team
