Revert from Version 2 back to Version 1
  • February 11, 2016
  • 1724 views
I had model templates that were entirely assembled with import features. I chose to recreate each part to the assembly and making them out of Creo 2.0 parts and then reassembled the assembly template that I replicated and checked it into WindChill. The problem I have now is that when I open previous projects where those original import featured templates were used are no longer being recognized, and everything is now scattered all over the place, like a really bad explosion view. I have many projects where this import featured template have been used. My guess is that those jobs where everything is scattered is resulting from their no longer associated with the updated "version". I could be wrong, yet, for a temporary band-aid solution, I am trying to revert back to Version 1.
Does anyone know how to revert from version two back to version 1?
Can you not just delete version 2 in WC?
Delete all iterations. This should return you back to the last iteration of version 1
