Revision = Latest vs Latest Revision filters in Folder View in MPMLink
When you edit a view in Folder Contents of a product you can customize a view and enter these criteria:
For context I was having similar issue in this article: https://www.ptc.com/en/support/article/CS370354
And the image above was taken from there. Can anyone explain why would I want to set Revision to All and Latest Revision to Yes? Does the first criteria even serve a purpose? When I delete it it doesn't make a difference.
