Run Cognos Report from Workflow
10.1 M040
Hi Everyone,
I have searched on this exploder and found a post from Jesse Holle that the API com.ptc.windchill.enterprise.ReportService.executeReport() can run a Cognos report and capture the output as a stream object. The only problem is that this API is not yet supported. Do any of you know of an API that can be run from a workflow to execute a Cognos report and capture the results as a stream?
Patrick Williams | Engineering Systems | c: 616.947.2110
[cid:image001.jpg@01CEFA40.D891AE40]
Hi Everyone,
