Running combine command creates an EMPTY windchill-all.ja file but the functionality is not working
  • January 23, 2025
  • 367 views
With reference to your response in this topic.
We are following same approach on WTPart create Page from classification node taking description as value and using it to a update name of that part.
But here thing is our custom function when we are calling in ootb .js then it works fine but as per article we should create a .jsfrag and then run the combine command to combine all javascript code in single.js file which is windchill-all.js.
But in our case after running that command windchill debug.js file getting updated correctly but EMPTY windchill-all.ja file got created and that's why our Functionality is not working as expected and we don't want to touch ootb .js file.
Please suggest the solution on the same where we are doing wrong thing.
Community Moderator
January 28, 2025
Hi @@_1647,
Thank you for your question.
Your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Also, feel free to add any additional information you think might be relevant. It also helps to have screenshots to better understand what you are trying to do.
Vivek N
Community Moderation Team.
