Search from excel to PDMlink
  • April 21, 2016
  • 2 replies
  • 1936 views
Can we connect a link between excel and pdmlink.  .. ? I am working on a specific project, where i want to search  available items in PDMlink from excel which is stored locally .. ?
I think the best OOTB option would be to create a Query Builder report and run it from Excel.
Read for more info here - Resource for reporting
and https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS162869
Thank you
Binesh Kumar
23-Emerald I
May 14, 2016
Guru,
Did Binesh Kumar‌'s suggestion help? Additionally, if you are looking to be able to search for and open Documents stored in Windchill directly in Excel you can use the Windchill Desktop Integration to do this5-14-2016 8-53-23 AM.jpg
gprasadn1-VisitorAuthor
Thanks for your solution, I will check and say you the result..
BR
Guru Prasad N
