Send to PDM causing error ATTENTION: Values associated with incorrect object
  • January 14, 2026
  • 44 views
I am using Windchill ProjectLink Release 13.0 and Datecode with CPS 13.0.2.0
Using the action "Send to PDM" is resulting in an error: "ATTENTION: Values associated with incorrect object." The objects are .PRT / .ASM / .DRW files.
They were created within the Project. We are now trying to send it to PDM. Tested to see if it was a permissions issue using an admin account, but same error occurs. I do not believe the objects are deprecated or abandoned - they have only been inside of that one Project. Much appreciation to any insight what the issue could be.
    Hi @ndele,
    Have you reviewed the MS logs for any errors or related information?
    ndele10-MarbleAuthor
    Hi @TDT ,
    When looking at the persisted log events, I found this synopsis:
    [ajp-nio-127.0.0.1-8011-exec-118] com.ptc.jca.mvc.controllers.ActionController - java.lang.reflect.InvocationTargetException - java.lang.reflect.InvocationTargetException
    When looking at the BackgroundMethodServer logs, there is no event during the same time in which the above statement happens. This happens a minute before the error, then there isn't anything in the log for several minutes:
    [QueueCheckerThread-37] wt.pom.statementCache.summary - StatementCache: wt.util.Cache%481960759 [size=50, count=4, hits=125, misses=4, overflows=0]
