avillanueva
23-Emerald I
23-Emerald I
October 11, 2022
Standalone WindchillDS for 11.1 to 12.0.2 upgrade
  • October 11, 2022
  • 2673 views
I've read the many posts and articles on this topic and am prepping to setup my environment. I planned on using my index server to temporarily host an 11.2 WindchillDS instance for use with upgrade target and later switch to OpenDJ. Just running it heck of time getting this installed.
First issue was lack of space on /tmp, worked around that.
Next was it complaining about the Java version not being higher than 1.8.0_202:
Invalid Java version. Java 1.8.0_202+ is required. *Installation Directory for Java for Windchill:
however, I downloaded Amazon Corretto 1.8.0_342 (OpenJDK 64-Bit Server VM Corretto-8.342.07.4). Following CS344918 , I downloaded the latest CPS update (17) which has an updated version of WindchillDS in it. No dice. Still not letting PSI install standalone WindchillDS. Any other thoughts?
Best answer by avillanueva
Yep, Removing the Java Options, suggested by cs178146 accepts the Java version. Now back to the original issue that admin setup my /tmp folder with hardly any space to complete install.  That should be easier issue to solve but strange that its not as simple to have PSI point tmp folder to another place.
avillanueva
23-Emerald I
23-Emerald I
October 11, 2022
Ok, came across this: cs266753  I was using Java options to work around tmp size issue. Does not like that.  Digesting this.
avillanueva
23-Emerald I
avillanueva23-Emerald IAuthorAnswer
23-Emerald I
October 11, 2022
20-Turquoise
October 12, 2022
I always do this for alternate tmp directory for the PTC Solution installers.
\rm -r /opt/ptc/Windchill/tmp_install
mkdir /opt/ptc/Windchill/tmp_install
chmod 777 /opt/ptc/Windchill/tmp_install
export IATEMPDIR=/opt/ptc/Windchill/tmp_install
Then run the installer...
