Summary: Upgrade from 9.1 M060 to 10.0 M040 or 10.1 M010
  • June 27, 2012
  • 3 replies
  • 1202 views
I only received four replies and I have posted them below. I think we
will upgrade to 10.1 M010. Thanks to those replied.
R10.1 M010 is already available and 10.0 M040 is some time in August. If
you plan for ESI, R10.1 has many ootb features. 10 M040 is also projected
for those features but I dont see any valid justification for 10M040.
WC10.1 m10 hands down. Its only a point release so I doubt its terribly
buggy, plus there is a bunch of cool new stuff in 10.1
I am sure he meant 10.1 M010 – this is what I am being told as well.
However, I use just the basics, no customization and we don’t use
ProjectLink.
We are live on M020 Windchill 10.0 with a lot of patches. I recommend M040
for 10.0, or later, if you can wait for whatever is next. Go with the
latest M-build you possibly can.
Rao
Xylem, Inc.
If you are a Pro/E shop, be sure to check the compatibility matrix for your current Pro/E version and 10.1, I believe, WF4 is not support in 10.1. /p
WF4 is listed as Not Compatible with WC10.1
Creo/Elements Pro 5.0m130 is planned for WC10.1
Creo 1.0 is listed as Not Compatible with WC10.1
Creo 2.0f000 is listed as Compatibility planned with WC10.1
Thank you,
Ben H. Loosli
USEC, INC.
ksreeniv1-VisitorAuthor
Thank you for this info. PTC also informed us that Creo 2 is compatible
with PDMLink 10.1 but not Creo 1 or WF5.
