The page occasionally requires refreshing the browser and loading for about a minute to display data
ZL_10925195
Version: Windchill 11.0
Description:
The page occasionally requires refreshing the browser and loading for about a minute to display data correctly. Upon checking the MethodServer logs, the following information is found:
caught cache server call exception
java.rmi.RemoteException: Unable to get remote cache entry; nested exception is:
java.rmi.ServerError: Error occurred in server thread; nested exception is:
java.lang.NoClassDefFoundError: Could not initialize class wt.project._Role
However, in reality, the relevant class does exist on the server, and programs that import the relevant class can execute normally.
AndrewK
Community Manager
(To:ZL_10925195)
Hi @ZL_10925195,
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Hi, can you identify which page is experiencing the performance problem and MS errors?
It's not just a specific page; this issue occurs on all pages. MS errors: caught cache server call exception java.rmi.RemoteException: Unable to get remote cache entry; nested exception is: java.rmi.ServerError: Error occurred in server thread; nested exception is: java.lang.NoClassDefFoundError: Could not initialize class wt.project._Role at wt.cache.RemoteCacheServer.getEntryInternal(RemoteCacheServer.java:322) at wt.cache.RemoteCacheServer.lambda$getEntry$18(RemoteCacheServer.java:253) at wt.cache.RemoteCacheServer.callTimeAndLogRemoteCallableLow(RemoteCacheServer.java:680) at wt.cache.RemoteCacheServer.callTimeAndLogRemoteCallable(RemoteCacheServer.java:652) at wt.cache.RemoteCacheServer.getEntry(RemoteCacheServer.java:253) at wt.cache.CacheManager.get(CacheManager.java:901)
Caused by: java.rmi.ServerError: Error occurred in server thread; nested exception is:
at sun.rmi.server.UnicastServerRef.dispatch(UnicastServerRef.java:386)
at sun.rmi.transport.Transport$1.run(Transport.java:200)
at sun.rmi.transport.Transport$1.run(Transport.java:197)
at java.security.AccessController.doPrivileged(Native Method)
Caused by: java.lang.NoClassDefFoundError: Could not initialize class wt.project._Role
at wt.project.RoleRoleTable.readVersion(RoleRoleTable.java:118)
at wt.project.RoleRoleTable.readExternal(RoleRoleTable.java:88)
at java.io.ObjectInputStream.readExternalData(ObjectInputStream.java:2118)
at java.io.ObjectInputStream.readOrdinaryObject(ObjectInputStream.java:2067)
at java.io.ObjectInputStream.readObject0(ObjectInputStream.java:1573)
