There is no Cache designated vault or active folder for Cache designated vault on Local Main Site
  • November 25, 2014
  • 2 replies
  • 7153 views
Can anyone please explain whats happening, i havent even changed the model and im getting an upload fail with the following conflict.
Best answer by Marco Tosin
Paul,
look at this discussion http://communities.ptc.com/message/164144#164144
Marco Tosin
Marco
In addition to this thread you can also visit:
Something probably caused Windchill's cache folder to get set to read only. Make sure there is free space available on the drive where the cache vault is mounted. This could also happen if files aren't getting synced from the cache vault to the master vault. That could cause the cache folder to fill up and get set to read only.
