Tibco HawkRandomAccessFile.dll starts with problems
I'm getting some log errors when start Tibco's services.
The log files says that can't find dependent libraries, but don´t show the ones, at least the names.
2023 Apr 18 17:42:39:521 GMT -03:00 HawkAgent.JACVMQASESI02 Error [Application] HWKXXX-000010 E:\ptc\esi_12.0\tibco\hawk\6.2\bin\HawkRandomAccessFile.dll: Can't find dependent libraries
2023 Apr 18 17:42:39:522 GMT -03:00 HawkAgent.JACVMQASESI02 Error [Application] HWKXXX-000018 In LFMicroAgent exception from scan thread: java.lang.UnsatisfiedLinkError: E:\ptc\esi_12.0\tibco\hawk\6.2\bin\HawkRandomAccessFile.dll: Can't find dependent libraries
at java.base/java.lang.ClassLoader$NativeLibrary.load0(Native Method)
at java.base/java.lang.ClassLoader$NativeLibrary.load(ClassLoader.java:2430)
at java.base/java.lang.ClassLoader$NativeLibrary.loadLibrary(ClassLoader.java:2487)
at java.base/java.lang.ClassLoader.loadLibrary0(ClassLoader.java:2684)
at java.base/java.lang.ClassLoader.loadLibrary(ClassLoader.java:2649)
at java.base/java.lang.Runtime.loadLibrary0(Runtime.java:827)
at java.base/java.lang.System.loadLibrary(System.java:1871)
at COM.TIBCO.hawk.agent.logfilema.HawkRandomAccessFile.<clinit>(HawkRandomAccessFile.java:71)
at COM.TIBCO.hawk.microagent.logfilema.LFStream.<init>(LFStream.java:41)
at COM.TIBCO.hawk.microagent.logfilema.LFMonitor.initializeStream(LFMonitor.java:110)
at COM.TIBCO.hawk.microagent.logfilema.LFMonitor.initialize(LFMonitor.java:104)
at COM.TIBCO.hawk.microagent.logfilema.LFMonitor.getData(LFMonitor.java:156)
at COM.TIBCO.hawk.microagent.logfilema.LFMicroAgent$ScanThread.run(LFMicroAgent.java:524)
This cause a problems on start or stop services, that can´t be automatized and necessary someone solved manually.
Plus, there a lot of services stayed locked on memory, and need to be killed manually.
P.S.: Apparently doesn't chash the working, but fill the server´s memory with stucked aplications repeteadly.
