Hello everyone,
I am currently facing an issue with modifying the default "Required" view in Windchill. Despite having wcadmin permissions, I cannot replace or update this system-level view. Here's a detailed overview of what I've tried and observed:
I want to replace the existing default "Required" view with a custom configuration that better suits my requirements. I do not want to create a new view; my goal is to overwrite or modify the existing one.
<TableColumnDefinition>
<name>IBA|fr.satys.plm.SecondaryReference</name>
<locked>false</locked>
<sortNumber>0</sortNumber>
<treeColumn>false</treeColumn>
<sortDescending>false</sortDescending>
<hidden>false</hidden>
<width>0</width>
</TableColumnDefinition>
When I modified the <name> of the view in the XML file (e.g., changing it to a new name) and imported it, I was successfully able to see the newly created view with the name I provided.
However, this is not the result I want — I need to modify the existing "Required" view directly, not create a new one.
⚠️And I can confirm that I am not even able to delete the existing "Required" view and replace it by importing my modified version.⚠️
Any guidance or insights from the community would be greatly appreciated!
Thank you in advance!
Salam Si Brahim,
Why don't you just edit the view from the UI and add the attributes Needed :
