Updating Parts via Patch Method Without Versioning: Is it Possible?
ozclkonur
"I want to update using the patch method with this API endpoint: http://************/Windchill/servlet/odata/ProdMgmt/Parts('OR:wt.part.WTPart:*********'), but it warns me that I need to check out first. Is there a way to update the part without checking in or out, without touching versions, etc.? If there is a method, could you explain it?"
Unfortunately there is no way to edit any WTPart by WRS without iterating it. Also with java it's not official supported to change an attribute without checkout/checkin.
