Upgrade Manager Fails
I am using Windchill PDMLink Release 11.1 and Datecode with CPS M020-CPS23
when we are executing the Upgrade Manager it is failing at verifying Upgrade path.
Here are the errors that I faced
INFO [UpgradeEventFirer] com.ptc.windchill.upgrade.logging.UpgradeFrameworkLogger - Task Execution Time: 375 milliseconds
2024-02-07T19:37:41,292 ERROR [main] com.ptc.windchill.upgrade.statemachine.UpgradeFrameworkStateMachine - State execution failed (with return type FAILED): ReportWriterUpgradeState(Verify Supported Upgrade Path)
2024-02-07T19:37:49,371 WARN [AWT-EventQueue-0] com.ptc.windchill.upgrade.reports.UpgradeToolOutputs - Unable to update dbHistory.xml in UpgradeManagerOutputs.jar - archived report may be out of date: Unexpected persistence exception transferring install and upgrade history contents.
Nested exception is: wt.pom.POMInitException: A persistence error occurred. System message follows:
Nested exception is: wt.method.MethodServerException: No active method context
