Upgrade Manager Failure
- June 10, 2024
- 2 replies
- 1345 views
Version: Windchill 12.1
Use Case: Upgrade Manager says my versions are incompatible.
Description:
When running UpgradeManager, the verify supported upgrade path task fails. I get the message: The upgrade path for the source system is not supported for an upgrade to this target system. The following required solutions on the source system are at an invalid level for this upgrade: IE, PDML, PJL, WNC.
Source is running WIndchill 12.0.2.10 with IE, PDML, PJL running 12.0.2.7 according to Windchill help.
Target system is going to 12.1.2.8. This is a clean initital installation on a new server.
I found CS242678 and ran the xconfmanager command, then reran UpgradeManager and get the same results.
