Upgrade PDM Essential 11.1 to PDMLink 11.1
I am using Windchill PDM Essentials Release 11.1 and Datecode with CPS M020-CPS07
When you start the PSI to upgrade PDM Essential 11.1 to PDMLink 11.1, the installation fails immediately. The system shuts down Apache but does not restart it and by error Apache does not respond. We also tried to start Apache by hand but it still doesnโt work
Here are the errors that I faced
INFO 2025-04-15 15:48:08 - Running sha1 command: C:\ptc\Windchill_11.1\Windchill\bin\windchill.exe --java=C:\ptc\Windchill_11.1\Java\bin\java.exe --javaargs=-Dwt.load.installer.serverManagerTimeout=300 com.ptc.wa.sha1utility.caller.SHA1GeneratorCaller C:\ptc\Windchill_11.1\Windchill C:\ptc\Windchill_11.1\Windchill\utilities\SHA1BaseReports 11.1M020-CPS08 false true
INFO 2025-04-15 15:48:09 - joining with std out thread
INFO 2025-04-15 15:48:09 - std out join complete.
INFO 2025-04-15 15:48:09 - joining with std error thread
INFO 2025-04-15 15:48:09 - std err join complete.
FATAL 2025-04-15 15:48:09 - Sha1 Command exited with error status = 1
DEBUG 2025-04-15 15:48:09 - Installation is Aborting. The installation cannot continue.
FATAL 2025-04-15 15:48:41 - Aborting installation.
FATAL 2025-04-15 15:48:41 - Installation is Aborting. The installation cannot continue.
FATAL 2025-04-15 15:48:41 - Sha1 Command failed.
FATAL 2025-04-15 15:48:41 - aborting: original exit_code = 2
FATAL 2025-04-15 15:48:41 - aborting: normalized exit_code = 2
DEBUG 2025-04-15 15:48:41 - SHUTDOWN REQUESTED
DEBUG 2025-04-15 15:48:41 - (X) commiting registry
DEBUG 2025-04-15 15:48:42 - (X) shutting down service manager
DEBUG 2025-04-15 15:48:43 - (X) cleaning up temporary directories
DEBUG 2025-04-15 15:48:43 - Exiting with exit code: 2
DEBUG 2025-04-15 15:48:43 - cleanUp()
DEBUG 2025-04-15 15:48:43 - calling cleanUpWin32()
