User assigned license & last login report
  • January 23, 2026
  • 736 views
Using the attached QML, I was able to retrieve the users assigned to their respective licenses. However, the report is also returning the associated team roles along with the license or group names to which the licenses are mapped.
Do you have any suggestions on how to exclude all team roles from the report? Although the criteria section technically allows filtering out roles, it is not practical to identify every possible role and create separate criteria entries for each one.
Best answer by joe_morton
You'll have to update your report. Instead of reporting Users directly linked to the license group, you'll need to report users in a group in the license group. Ex: User -> Group -> License Group
Just keep in mind that once you make that update, the report won't return any information on a user who is directly assigned a license. Ex: User -> License Group
You'll also want to consider if you have subgroups. Ex: User -> Subgroup -> Main Group -> License Group
For the reporting to work, you may need to create several reports to cover all cases of license assignment that you use at your company. (Direct assignment, 1 level group, 2 levels groups)
The only other way (I know of) would be to create your own Java Method, and use that in your QML. That would be the way to have a single report that can recursively navigate group structures to get the final license assignment, regardless of how many group levels there may be.
Fadel
23-Emerald I
January 26, 2026
try this ,I used a dummy trick , all license groups starts with PTC:
Buiꓘa
FYI: To include all PTC license groups, including those not beginning with PTC (e.g. License Exclusion and Platform Structures), filter groups where their description includes the word 'license'.
Fadel
23-Emerald I
January 26, 2026
@mmeadows-3
license exclusion is not a license group ,and  its intended to be used only for admins to test actions.
the "platform structure" that you mean  is also not a license one , the license platform license one has well  PTC in its name :
Buiꓘa
