Prepared build.xml as below
<target name="deploy" depends="init">
<echo message="Deploying workflow ${workflow.file}..."/>
<java jar="" fork="true" failonerror="true">
<arg value="wt.load.LoadFromFile"/>
<arg value="${workflow.dir}/${workflow.file}"/>
<classpath>
<pathelement path="${wt.bin}"/>
</classpath>
</java>
</target>
Suggest the correct way to deploy data in windchill 12.0
Hi @RS_10128209
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best regards,
Its got solved using CCD build framework
