When searching for a single piece of text in the "Description" section of a Change Request via the Keyword search in Windchill 10.2, the Change Request is not found. Is that expected behavior?
If I search for a single piece of text in the "Name" of a Change Request via the Keyword search in Windchill 10.2, the Change Request IS found.
The keyword search is only looking at "Name" and "Number". You will need to perform an advanced search and add "Description" to your criteria.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS80334
Thank you for that insight Tom. Adding the field "Description" to a Saved Search did the trick!
