Windchill 11 Linux - Windows Creo 2 worker. dvconjobDoJob
  • May 23, 2018
  • 2325 views
Attempting to setup Windchill 11 Linux for publishing on Windows CAD Worker. CAD Worker on Win 7. Creo 2 m230. Install and check connection okay. Works on other machines.
Keep getting error dvconjobDoJob unable to parse XML file. This is bound to be a security issue. If you know how to solve this please help. This is a bit of an emergency.
Best answer by wbowling
Located problem. The FTP server did not have a virtual directory. WVS configuration set to point at ftp:/ initially. With virtual directory defined the configuration was set to ftp:/ws_pub, which enabled the data to be written.
wbowling1-VisitorAuthorAnswer
