Windchill 11 PSi Failed with Error "Password validation failed. The password does not meet Windows policy requirements because it is not complex enough" although we ar eproviding comples password
we are upgrading to Windchill 11 M010 from 10.2 M030.
But while Windchill 11 Installation, it is getting failed Failed with Error "Password validation failed. The password does not meet Windows policy requirements because it is not complex enough" although we are providing complex password. This error comes while new DB schema and user creation in Sql Server 2012.
When check PC knowledgebase, found that this issue is know and it is a PSI bug and SPR is filed for this issue. workaround is to disable the domain password policy but unfortunately it is not possible in our environment as domain controller person said no for disabling this policy.
PTC is saying they do not know when it will be fixed. But we had shared server upgrade rollout plan to all stake holders and now we are delayed by two weeks.
Is there any follow members who also found this issue while upgrading to Windchill 11 M010 with SQL or Oracle server?
Also is there any workaround or solution apart from disabling the password policy?
Thank you all,
Shekhr SIngh
