Windchill 12.0 - Any printing/downoad enhancements ?
  • June 9, 2022
  • 2 replies
  • 1422 views
Watched quite a few videos on Windchill 12.0, thought I saw an enhancement where from a search on a drawing, you could download or print the drawing right from a menu. I looked again thru numerous videos and can't find any such enhancement. Can anyone confirm if this functionality was added ?
If so, what exactly will it do ?
On a related note, for Windchill 9.0 a community user came up with a utility called download pdf or pdf. It added a menu pick for downloading the published file.  There is also a some java code and files that need to be updated for the back end that runs from a Windchill shell.  In Windchill 11 I was able to get the backend utility to work, so basically from a list of drawing files, you can download the published reps with just one click.  Wasn't able to get the utility to run reliably thru the Windchill interface.
There are two extensions available Please go to https://windchill-extensions.ptc.com/
PDF quick access is free and CAD Quick is paid.
For CAD quick we did similar customization to download CAD.
Regards
Ajit
ehowanice12-AmethystAuthor
Ajit - Thanks for the information. We're still on Windchill 11.0, there doesn't appear to be Windchill platform installer for 11.0 anymore.  Looking at the documentation/instructions at one point there was an installer for 11.0.  The PDF quick access starter is available for 11.0.  Looking on the PTC support site don't see any info regarding a platform installer for 11.0
18-Opal
June 10, 2022
@ehowanice , hi
I have a download utility that does what you described.
From Windchill you open a search page and enter CAD Drawing numbers (you can use wildcards too)
The search returns all CAD Drawings that match the search criteria.
User then checks which drawings they want (there’s a ‘Select All’ and a ‘Unselect All’ button too) and then the user selects the ‘Download’ button.
The utility then downloads the published pdf files. If any drawing has not been published the utility will automatically publish it and download the resulting pdf file.
The code was was written in 10.x and has worked just thru 12.1 (current latest release).
The utility could easily be expanded to be run from OOTB search results menu and the drawing action menu.
If you’d like to learn more feel free to contact me at:
windchill.developer@yahoo.com
