Windchill 12 Workgroup Manager
  • November 30, 2023
  • 2 replies
  • 1358 views
We have some schematics files that we are trying to import. We can import them into windchill using the web browser in Creo, but a normal browser does not import correctly. I've also tried using the workgroup manager, but I cannot see the *.RSD files from the workgroup manager.
Is there a way to enable the import of RSD files into the workgroup mananger workspace?
Articles:
avillanueva
23-Emerald I
23-Emerald I
December 1, 2023
Please read this article first: https://www.ptc.com/en/support/article/CS377575?source=search
Creo Schematics 7 used a workgroup manager to load data into Windchill. It appears that Creo Schematics 9 is not supported. If you are using a later version of Schematics or are on Windchill 13, see this site:
https://virtual-interconnect.co.uk/software/product-lifecycle-management/wncbridge/
Aaronm8714-AlexandriteAuthor
I'm just looking for a way to upload files into windchill manually. I can do it with Creo Parametric, but I was hoping to see a configuration file where I could add to the list of available files. Similar to how you add to the list of files in Creo.
avillanueva
23-Emerald I
23-Emerald I
December 1, 2023
Its more than just a file. That is why they built a Workgroup Manager and handle then as EPMDocuments. It has a structure. To properly manage them, you need to use a supported method and that is via the 3rd party integration. For example, I manage my Cadence data as WTDocuments but had to customize a bunch of things to get the right level of integration a Workgroup Manager would do OOTB. If you load schematics as WTDocs via browser, they cannot interact in the Creo workspace since it needs to be managed as an EPMDocument.  Recommend contacting Virtual Interconnect.
