Windchill Desktop integration problem incorrect value of version.Iteration shown in document.
I work At Continental and we have the following below (See pictures below) situation.
- When I open a Word document by (default I Open and download, asking for check-out), now I see that the resulting value showed in "word" is AA.6 but due to the fact that I just checked-out it should be AA.7 (this value inserted by windchill menu
), I have no clear which can be the problem ?
- When i create document in wise (In autonumbering mode) is mandatory to load local file, but in this case I have later to check-out download, rename the file and upload again, and chek-in !?
- Also another task to see deeper is the procedure of "Save as" of Microsoft office documents !?
The online resource are not enough precise and do not describe any best practice or example, can somebody share his experience or suggestion regarding this topic ???
