Windchill SSO and Local Users
  • July 15, 2024
  • 2 replies
  • 2798 views
We've set up SSO in Windchill with Shibboleth. This works fine. But now we want to login with a local user (like wcadmin) and don't know how to do this. We always get redirected to the Shibboleth and Microsoft Page. Does anyone know how to get this achieved?
Best answer by avillanueva
There is another option with a similar configuration that I am testing now:
https://www.ptc.com/en/support/article/CS372501?source=search
This has you first hit a special page first.
This support article explains how to do this:
https://www.ptc.com/en/support/article/CS355355
avillanueva
23-Emerald I
23-Emerald I
July 16, 2024
Hi!
The article that you're referring to has been hidden from public view. Do you have access to it, or can divulge its contents or proposed method?
Thanks! We tested a similar solution that was paired with an ipmatch towards REMOTE_ADDR only to allow basic login from certain IP-adresses. We wanted to try limit administrator login from certain locations only. That worked pretty well, though we saw some challenges when using SSO and basicLogin with WGM and DTI, and I had hoped to find some more information about other solutions. I will revisit this later though, after some new rounds of rehosting, patching, and migration.
It did not contain +protocolAuth, so I'll keep this in mind when I later will reapply config.
