Windchill Workflow - CN and CN State sync using sync robot
Srinivas_256
Version: Windchill 12.1
Use Case: We are looking to implement lifecycle state synchronization between Change Notice and Change Activity in Windchill. Specifically, we want the lifecycle state of a Change Activity to automatically update based on the state of its associated Change Notice—and vice versa. While reviewing the workflow configuration, we noticed the object event "Change Notice State Change". We would appreciate guidance on how this event functions and how it can be leveraged to achieve bidirectional state control between Change Notice and Change Activity. Could you please advise on: How this event can be configured within workflows? Whether lifecycle transitions can be triggered automatically in both directions? Any best practices or limitations we should be aware of?
Description:
Anyone implemented change notice state change in workflow
It is very easy to do with a Method Robot.  Use parentChangeOrder as below.  I've only done this in Activities.
Hi @Srinivas_256,
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
Catalina
PTC Community Moderator
PTC
