Windchill Workgroup Manager - Siemens NX CAM
  • April 30, 2024
  • 5384 views
Once the connection server is online NX lost the key to use Manufacturing Part.
The NX properties are complitely ignored about NX Manufacturing template.
Template for part, assembly and drawing are ok. We lost only template for Manufacturing template
Any ideas about it?
Best regards
Gianpaolo
Attached you will see the different steps
Step 1-4 OFF line behaviour
Step 1 =  Server manger OFF - no server
Step 2 =  Open a CAD part
Step 3 =  create the manufacturing part
Step 4 = open the manufacturing part linked to CAD Step 2
Step 5-8 ON line behaviour
Step 5 =  Server manger ON - on line
Step 6 =  Open a CAD part
Step 7 =  create the manufacturing part
Step 8 = open the manufacturing part is not linked to CAD Step 2
Best answer by GianpaoloGallo
Great Dobi!!!!!
your advice works perfectly!!!!!
I missed in the assebly load options the custom folders where all the custom are uploaded. (Machine..etc...)
Great! Great Great!
Gianpaolo
This could have to do with your NX model tree...
You have a lot of wavelinked bodies. Is your "Delay Model Updates" on? NX is particular about references - especially when it's connected to Windchill - and there are types of references Windchill doesn't (yet) support (like references from routing object geometries if you do tubing or harnesses).
Are the bodies you're linking available in the workspace (and therefore available in the %PTC_WFS_ROOT% folder of your cache)?
When you're opening your CAD, make sure to open with Assembly load options set to "Fully Load" too...
GianpaoloGallo12-AmethystAuthorAnswer
Great Dobi!!!!!
Great! Great Great!
Gianpaolo
Hi Dobi,
I know about the Load_options.def but inside of this doc there is not info about Windchill.
Once I login with Server manger ON - on line this option is changed and NX link the Workspace.
Then I manually have to add the second load path to fix it.
# custom_dirs.dat: Directories to search for Unigraphics customizations
# Copyright (c) 1999 Unigraphics Solutions, Incorporated
# Unpublished - All rights reserved
# This file is used to specify directories which will be searched for
# menu files, toolbar files, dialog files or UDO libraries. The directories
# added here may or may not exist, to allow the same file to be used at
# multiple sites. When Unigraphics starts up, it will check each entry, if
# the directory does not exist, the line will be discarded as if it was a
# comment. Comments are allowed, and must start with a # in column one.
# Directories must be listed one per line, with nothing else on the line. The
# directory may include environment variables, by specifying $variable. If
# a $ is needed in a directory, it may be specified using $$, e.g.
# /users/my$$ would be the directory /users/my$. The file may be made to
# work on UNX or WNT, on WNT any / characters will be replaced by \.
# A #include construct is supported to include other files, to make it easier
# for individual users to customize their runtime environment. Finally the
# location of this file is controlled by the environment variable
# $UGII_CUSTOM_DIRECTORY_FILE which by default points to
# $UGII_DEFAULT_MENU_DIR/custom_dirs.dat. Customers with a number of
# customizations, or a number of third party products have two ways to set
# this up:
# 1. This is the preferred method. Create a file on a network drive
# that has lists all of the directories of the customizations. Then the
# environment variable UGII_CUSTOM_DIRECTORY_FILE can point to this shared
# file, so that all users will load the third party software. When a new
# software tool needs to be added in, the global shared file can be updated
# to give all users access to the new software.
# 2. Edit this file and add the directory to it. The problem with doing
# this is that different users will have local copies of the NX software,
# and so different files that need to be kept up-to-date.
# Customers should feel free to edit this file.
# Customer modifications can follow on here
C:\PTC\ROOT\WF_ROOT\.cadadapters\x86e_win64\ugnx1926
