Windchill logs Editable
If Windows is hosted on the Windows OS can the old and current logs be editable?
Can you clarify what you mean? Are you referring to adding comments?
I am not sure why the OS should have any bearing on this. Logs should be restricted to only the user who runs Windchill. This would prevent someone from removing logs to cover tracks of a breach. Ideally, you should be collecting logs to a central threat detection package for log analysis. These are just text files so if you grant access, they are editable.
Enter your E-mail address. We'll send you an e-mail with instructions to reset your password.
