Windchill publish rule without prefix from DRW
  • January 17, 2020
  • 2 replies
  • 2944 views
My client wants that generated PDF and DXF from DRW should have the same name as the primary file. Now it looks like this:
Files should be named testpart.dxf and testpart.pdf without prefix "dxf_" and suffix "_drw".
My publish rule look like this:
Spoiler
<rules xmlns="http://www.ptc.com" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.ptc.com/PublishRulesSchema.xsd">
	<authoring-application name="PROE">
		<additional-files name="DrawingPDF">
			<file display-label="PDF" type="pdf" default="true" output-prefix="pdf"/>
			<file display-label="DXF" type="dxf" default="true" output-prefix="dxf"/>
		</additional-files>
		<param-set name="Share with WTDocumentReleased Drawing">
			<post-publish name="delegate">com.ptc.wvs.server.publish.AdditionalFilesPostPublishDelegate</post-publish>
			<post-publish name="published-content-link">pdf</post-publish>
			<post-publish name="name">{EPM_NAME}</post-publish>
			<!-- <post-publish name="lifecycle-state">RELEASED</post-publish> -->
			<post-publish name="lifecycle-template">Basic</post-publish>
			<post-publish name="type">wt.doc.WTDocument</post-publish>
			<post-publish name="folder">/default/PDFs</post-publish>
			<post-publish name="additional-file-primary">.*\.pdf</post-publish>
			<post-publish name="additional-file-secondary">.*\.dxf</post-publish>
		</param-set>
		<condition name="IS_Drawing">
			<attribute name="epmdoc_name" regex=".*\.drw" />
			<!-- <attribute name="epmdoc_lifeCycleState" value="Released"/> -->
		</condition>
		<if condition="IS_Drawing">
			<publish evaluate-rules-on-republish="true" additional-files="DrawingPDF" param-set="Share with WTDocumentReleased Drawing" on="create-representation"/>
			<publish evaluate-rules-on-republish="true" additional-files="DrawingPDF" param-set="Share with WTDocumentReleased Drawing" on="schedule"/>
			<publish evaluate-rules-on-republish="true" additional-files="DrawingPDF" param-set="Share with WTDocumentReleased Drawing" on="checkin"/>
			<publish evaluate-rules-on-republish="true" additional-files="DrawingPDF" param-set="Share with WTDocumentReleased Drawing" on="unknown-source"/>
			<!-- <publish evaluate-rules-on-republish="true" additional-files="DrawingPDF" param-set="Share with WTDocumentReleased Drawing" on="manual-post"/> -->
		</if>
		<publish evaluate-rules-on-republish="true" on="checkin"/>
		<publish evaluate-rules-on-republish="true" on="create-representation"/>
		<publish evaluate-rules-on-republish="true" on="schedule"/>
		<publish evaluate-rules-on-republish="true" on="unknown-source"/>
		<publish evaluate-rules-on-republish="true" on="manual-post"/>
	</authoring-application>
</rules>
Thank you for help.
MattPat14-AlexandriteAuthor
I see that value output-prefix is mandatory. Is it any way to solve it ?
The only possibility I'm aware of ist to create an AfterEDRLoader like described in the case CS216668.
Ok all is clear but this method output file names will be: source CAD file name + Windchill version number. i.e. Format: <CADName>_<IterationInfo>.extension (e.g. MYCADNAME_A.1.stp)
It's not what I'm looking for because I need only a name from drw file.
Hi Tom,
Thank you for your help. Summarizing I have to install Afterloader hook method and after that modify the Java code of Afterloader? Sorry for my confusion but it's first time to me for making Windchill customization.
