6-Contributor
September 3, 2025
advanced Search Results Customize View List: Simple Search customize View
  • September 3, 2025
  • 2 replies
  • 228 views
I am using Windchill PDMLink Release 13.0 and Datecode with CPS 13.0.2.6
After upgraded windchill to 13.0.2.6, after that we are unable to Add "Title " in advanced Search Results Customize View List: Simple Search, most of the Column is missing, please provide info that how to add those Column.
Here are the errors that I faced
not found any "Title "in Available Column "Customize View List: Simple Search"
Catalina
Community Moderator
September 3, 2025
Hi @SW_369
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry. For example:
  • Is the missing "Title" column specific to certain object types (e.g., WTDocument, EPMDocument)?
  • Was the view configuration migrated or recreated after the upgrade?
  • Are the attributes (like "Title") still visible in Advanced Search or other views?
Please add screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Here's what a good question for Windchill looks like.
Thank you for your participation and please let me know if you need further assistance!
Best regards,
Catalina | PTC Community Moderator
avillanueva
23-Emerald I
23-Emerald I
September 3, 2025
"Title" is not an attribute to all objects. You did not mention which object you are searching on. Title is an attribute on WTDocuments so what you need to do is select documents as the object you are searching for from My favorite Types first. The customizable views will be specific to that object type. From there you should be able to see the Title attribute as selectable. You did mention upgrade so it should not hurt to try clearing cache and tomcat compiled pages but I do not think your issue lies there. Screen shots help greatly.
