8-Gravel
October 24, 2016
breaking references
  • October 24, 2016
  • 8453 views
Hello
I'm trying to remove 2 parts from my Creo 2.0 workspace, but Windchill insists that they cannot be removed without also removing the parent object.  The parent object does not use these 2 parts.  How can I break the link between the parent and children?
Thank you
Best answer by manjunathrv
You may see some failed or missing reference in the Reference viewer window. You can RMB on the missing ref and hit break references.
Sometime you may not find the Break ref option. That time find the feature that is referencing this missing reference, go to that feature and redefine the feature to remove missing references.
use the reference viewer to check for missing references and try to break them.
8-Gravel
October 25, 2016
Hi mrv,
I got that far, but I can't figure out how to break the references in reference viewer.  Can you help me out there?
8-Gravel
October 25, 2016
That's kind of what I was afraid of, no break break references option.  Thank you for your help.
