edit process template in trouble
  • February 7, 2014
  • 2 replies
  • 2197 views
Hello I have a big problem about edit a wfprocess template.
Its display warn view in my computer.
What can I do to fix this prolblem!?
Best answer by shussaini
Ensure the graphics card driver is upto date. You can also then try with the following setting
1. Navigate to Java Control Panel > Java > Java Runtime Environment > User
2. Add line to Runtime Parameter field:
-Dsun.java2d.d3d=false -Dsun.java2d.noddraw=true
3. Restart Workflow Administrator
4. Also clear the Java cache.
Hope that helps.
regards
~Syed
Did you attach the correct image? I don't see an error message.
TZ_011-VisitorAuthor
This Windchill R10 is current production service.
My PC is display well In my company, but show warn width/height in my home with my own computer.
I try to figure out what problem between this two computers.
I try to edit with IE and FireFox.The result is same.
home: win7/ IE11/firefox(the lastest) /jre7u51
company: win XP/ IE8/firefox(the lastest) /jre6u21
Its any problem with Jre7?
No, it's the graphic driver.
shussaini16-PearlAnswer
Hope that helps.
regards
~Syed
Thank you very much to solve my problem.
My computer insalled jre 64 and x86.
I trey to command line 'javaws -viewer' to set this parameter and do well.
Good to hear that your problem is solved. Also, refer the tech support bulletin about Java 7 issues here.
Regards
~Syed
