i want to load the product template through load from file
  • May 19, 2024
  • 3 replies
  • 2755 views
I just unzipped the product template, i fond two xml TAG-0.xml and TAG_ContainerTemplate-0.xml. iam unable to load
Best answer by HelesicPetr
Please @RaikarRaghu
can you understand that you use wrong container to load?
If you download something from Windchill do not expect that you can easily load it by load from file instantly.
share the XML and others can see where is your issue.
PetrH
Community Moderator
May 23, 2024
Hi @RaikarRaghu,
Thank you for your question.
I’d like to recommend to bring more details and context to your initial inquiry
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Community Moderation Team.
avillanueva
23-Emerald I
23-Emerald I
May 23, 2024
I've done this before where I downloaded the product template, extracted the files, edited and want to import back in. Are you looking at updating existing contexts? Or are you looking at updating the product template for new products? If its the latter, I recommend zipping it back up and using the web UI.
You can provide the modified template file back again.
As an aside, once, a long, long time ago,  I did take a product template, extract the files and make ACL changes that I want to propagate to all existing contexts.  It only allowed me to add but I took a portion of the template, not the whole thing. I had to run it for each context. In hindsight, I was better off make the changes via the UI which is a PITA but I did not have to fight with the command line.  I was able to create a check report in Excel that can help spot deviations between the ACLs which would in my case.
Community Moderator
May 29, 2024
Hello @RaikarRaghu,
It looks like you have a response from a community member. If it helped you solve your question please mark the reply as the Accepted Solution.
Hi @vnamboodheri
Thank you  for your response.
Yah i tried by loading that xml through import in UI level its importing. Now i am trying to load through loaders.
In the below image, i import the Tag-0.xml through UI level, template get created , and same xml i tried through loader it was failing.
this is my bat file, once i run that bat file it will execute the load command from the windchill shell.
error message after the running the load command
HelesicPetr
Hi @RaikarRaghu
the log says that you use organisation container instead of product container.
so your xml can be bad.
