link between WTPart and WTDoc for 15.000 files as "described by" relation out of a spreadsheet
Hello everybody,
we have ~15.000 files (.pdf/.zip) which we like to import into our Windchill 11.0 M030 system. The upload and the manually setting of the correct version we already can do by our own. The missing last step is the link between the existing WTParts and the new added WTDocs as "described by" documents (version depending). Is there a way to use a spreadsheet which connects the filename with the WTPart Number (materialnummer), maybe with interim step adding the document numbers to it?
I read the Windchill help, but I miss the right keyword to get to a solution. Would be great if you can give me a solution note.
Best Regards,
Johannes
