method call failure about wt.method.RemoteMethodServer under eclipse
  • May 27, 2024
  • 977 views
I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.2.11
I set up a developing environment for the programmer,then make a simple application to invoke the method of wt.method.RemoteMethodServer.But I didn't succeed.
Windchill verison: 12.0.2.11
Eclipse:4.17.0
Java: 11.0.19
I
>>>>>1>>>>>
Hello,wcadmin
>>>>>2>>>>>
Exception is >>>>>wt.util.WTRemoteException: unable to call remote methods;Nested exception are:
java.lang.ClassNotFoundException: com.HelloWindchill
    HelesicPetr
    Hi @user_wg_1666666
    Your class is not defined or is not located in the Windchill location
    the correct class location for  HelloWindchill.class should be .../Windchill/codebase/com/ folder
    PetrH
    18-Opal
    May 30, 2024
    Hello user_wg_1666666,
    Was the information provided helpful ?
    KR,
    Charles.
    The links below are valid references:
    https://www.ptc.com/support/article/CS24105
