Hello, where can i donwload t MPMPLink for windchill 13.0?
I can't find it on Order or Download software updates
Many thank's
So we go back to the previous answer:
- either you don't have an active maintenance contract, and therefore you don't see the SW that you don't have under contract (or you never bought it)
- if the above is not true then there is a problem with your user and related rights so you need to open a call to PTC support
You pick 'MPMLink' before you pick the software version.
as you can see for me is not available and visible
There are two cases:
Or, as Tom already wrote, you have to select the right section to see MPMLink SW
Your image looks like this
i can't find mpmlink
