notification issue
  • October 26, 2015
  • 2732 views
Hi All,
I have an issue with notification queue.
Every time I query an object using code and update it, an entry is created in notification queue.
I want to avoid this.
Any help would be appreciated.
Regards
Sudeep
Do you have a subscription enabled for those objects which are updated through the query? What your query does?  Do you have an advanced life cycle for the objects you are trying to update?
Thank you
Binesh Kumar
Barry Wehmiller
spai-21-VisitorAuthor
I am querying latest version of a part. Here is the code i am using:
  1. Queryspec:
    QuerySpec querySpec = new wt.query.QuerySpec(WTPart.class);
    querySpec.appendWhere(new wt.query.SearchCondition(WTPart.class, "master>number", wt.query.SearchCondition.EQUAL, partNumber, true), new int[]{0});
    querySpec.appendAnd();
    querySpec.appendWhere(new wt.query.SearchCondition(WTPart.class,"view.key.id",wt.query.SearchCondition.EQUAL,viewNum), new int[]{0});
    QueryResult queryResult = PersistenceHelper.manager.find((StatementSpec)querySpec);
    if(queryResult.hasMoreElements())
        part = (WTPart) PartHelper.getLatestVersion((WTPart) queryResult.nextElement());
  2. Info Engine Task:
<ie:webject name="Search-Objects" type="OBJ">
   <ie:param name="INSTANCE" data="<%=processor%>"/>
  <ie:param name="ATTRIBUTE" data="name,number,view.id^name" delim=","/>
  <ie:param name="dbUser" data="wcadmin"/>
  <ie:param name="PassWd" data="wcadmin"/>
  <ie:param name="WHERE" data="(number='<%=partNumber%>')"/>
  <ie:param name="WHERE" data="(view.id^name='<%=viewName%>')"/>
  <ie:param name="VERSION" data="LATEST"/>
  <ie:param name="TYPE" data="WCTYPE|wt.part.WTPart"/>
  <ie:param name="GROUP_OUT" data="partInfo"/>
</ie:webject>
All the objects have Basic lifecycle.
Hi Sudeep,
The above expression only queries the data, can you share the the API's used to update the object .
Bhushan
