"Mega" Life cycle history table
  • November 4, 2024
  • 4 replies
  • 1770 views
Is there a way to export all the the life cycle history tables from a given object type?  I want to see all the state changes and when they occurred from all of a given object type.
joe_morton
18-Opal
18-Opal
November 4, 2024
You could build a report using query builder. Just link the Object you care about to the Life Cycle History table. Example:
Just keep in mind, if you don't add any additional criteria, this will be a massive report.
thanks.  unfortunately I'm more of a user of WC instead of an admin and I don't have ability to create reports.  I was hoping there was a capability on the user side to create a similar results.
thanks
In larger companies, Even Windchill admins do not create the Report (Templates Technically). You need to ask your Windchill Solution Owner. Typically a leader from your business team who owns the solution (delivered from your IT).
Windchill admins, though extremely knowledgeable, needs a CR to work on stuff like these. Depends on how new capabilities are introduced in your company.
Technically, there is a solution as mentioned by Joe.
Cheers
Hari
Community Moderator
November 12, 2024
Hi @kmccormack-2,
I wanted to follow up with you on your post to see if your question has been answered.
If so, please mark the appropriate reply as the Accepted Solution for the benefit of other members who may have the same question.
Of course, if you have more to share on your issue, please let the Community know.
Vivek N
Community Moderation Team
18-Opal
January 11, 2025
@kmccormack-2 ,
I think the best you can do at the user level is to make a custom tab and in that tab display Version History and Lifecyle History. This would at least allow you to click on any iteration and see its Lifecycle History.  The page will instantly refresh to show to the selected iterations Lifecycle History, so it's a least user friendly.
Other than that, as @joe_morton mentioned, have your admin make a Report.
FYI, any admin worth paying should be able to do this.  If they can't you need new admin as it's pretty simple to do it.
Thanks everyone!!!   Unfortunately, I'm not in a role to do any of the things yall suggested.  I'm just a basic user.  I appreciate all the feedback though.
Windchill on!!
Kenny
22-Sapphire I
January 23, 2025
See my posting earlier in this created today.
