rehost on Linux
I'm getting an error with the rehost utility for Windchill 12.0.0.0 on a Linux system. Oracle is on the same server and it is running. I can connect to Oracle via sqlplus <dbUser>/<dbPassword>. Windchill was installed as the root user and I'm running rehost.sh as root in a Windchill shell.
But the rehost is failing with "java.sql.SQLRecoverableException: IO Error: The Network Adapter could not establish the connection," and specifically "java.io.IOException: Connection refused, socket connect lapse 0 ms. <hostname_here>/0:0:0:0:0:0:0:1 1521 0 3 true" with "target.db.hostname" in the rehost.properties file set to the hostname. I also tried setting target.db.hostname to 127.0.0.1.
This is on a DEV server, so it is not configured with a domainname.
Anybody have troubleshooting tips?
