same Headers / linking Headers for a report with subreports?
Hello everyone,
I have generated a report that contains 6 subreports. All the subreports shall have some fields in the header and footer that are the same for each subreport (i.e. name of the system) but also fields that are specific for each subreport (i.e. type of analysis (FMEA, FTA ...)). When I use this template for a different system I have to change the fields on each of the subreports. This is very time consuming and can lead to errors since I have to generate reports for 70+ subsystems.
My question is: Is it possible to have a header that contains fields that are specific for each subreport and a header that contains fields that are needed on each subreport? Or is it maybe possible to "link" labels between reports so I have to change it in one place? Or is there a different solution to overcome my problem?
Thanks and best wishes.
