windchill workflow stuck
  • January 11, 2024
  • 2428 views
Hi Guys,
i am facing workflow stuck issue. it is not moving to next person for approval. image attached.
please help.
Sandeep C.
Best answer by HelesicPetr
Hi @Sandy7
You've just jumped over the task , you need to do manually.
The operation "complete" does not call the code again. It just move the process forward.
All the automatization has to be done manually from that finished node.
PetrH
HelesicPetr
Hi @Sandy7
If the process is promotion request where the changing state is done automatically to the locked state then the data have to be checked-in not check-out.
Check in the data and create new promotion request.
PetrH
Sandy712-AmethystAuthor
Hi @HelesicPetr ,
it is actually CN. i checked those assembly and drawing. it is in checked in state only.
br,
sandeep
HelesicPetr
Hi @Sandy7
The error shows different information
It seams that your WF is stacked when it should have changed the states.
You need to open the actual workflow find the node where the wf is stopped and finish the node manually as a administrator
PetrH
