windy.MiscLogEvents has 19M records; Not purging automatically
  • March 3, 2026
  • 3 replies
  • 65 views
I am using Windchill PDMLink Release 13.0 and Datecode with CPS 13.0.2.4
windy.MiscLogEvents has 19M records and DB has gown 100% in size in the last 3-4 months. CS178198 states to contact support if >10M records. Need assistance cleaning out the table and fixing maintenance routine to auto-purge.
Here are the errors that I faced
No errors; just table size issue.
    Best answer by mmeadows-3
    The MiscLogEvents table exists so we can see MS Log file errors through the Server Status > Monitoring Tools > Log Event Histogram page.
    This article covers MiscLogEvents fairly well.
    https://www.ptc.com/en/support/article/CS42494
    The content of this table is intended to be temporary, and it is OK if the records are deleted.  More will be generated...
    So, I would start with cleanup.
    https://www.ptc.com/en/support/article/CS178198
    • Probably need truncate this table before enabling the schedule; because Database SQL cannot delete 10 million table rows
    https://www.ptc.com/en/support/article/CS411345
    As DB user:
    truncate table MiscLogEvents
    Then I would try to understand and correct the cleanup failure.  It could be a queues issue or something was blocking the cleanup.  Sometimes cleanup starts working just because you truncated the table.
    Community Moderator
    March 9, 2026
    Hi @PP_8422751,
    Thank you for your question.
    Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
    Anurag
    As DB user:
    CS42494 covered my issue with both TRUNCATE and PROPERTIES file change to stop from repeating.
    Thanks for the assistance!
    PP
    Community Moderator
    March 18, 2026
    Hi @PP_8422751,
    Anurag
    Yes, thanks!  Updated and marked as answered.
