wt.LoadFromFile command errors out
We are moving our sever from 2003 to 2008. After rehosting PDMLink on the new server, we have been able to log in, check in, check out, revise, etc. Behaves normally.
In a windchill shell we are not able to execute the wt.LoadFromFile command, errors out - The operation: "getPrincipal" failed. Had a warning on https:<servername>/Windchill/wt.properties not found - using local properties.
Also the windchill wt.auth.Authentication errors out (same thing, but more verbose java errors)
Window 2008, PDMLink 9.1-m070, running ssl with self signed certificates.
We did this same process on our open network and everything works fine.
On our closed network we have this problem.
Any idea appreciated. So far the hot-line doesn't have a clue.
David Haigh
Phone: 925-424-3931
Fax: 925-423-7496
Lawrence Livermore National Lab
7000 East Ave, L-362
Livermore, CA 94550
Errors
Load from file errors:
David Haigh
Phone: 925-424-3931
Fax: 925-423-7496
Livermore, CA 94550
Errors
